Front Door Panel removal on '98?
You can (and should) pick up a door panel remover. It will run you about $8 (I paid $7.99) for one. Basically it's a modified screw driver that allows you to pop off the door panels without breaking anything.
Also, if you want to go the cheap route, a pair of Pioneer coaxials will do the job as far as speakers go. If you want to get fancy, pick up a nice pair of component speakers (give CDT a try).
I blew my front two stock speakers on my Neon in literally three weeks, they are pretty ****ty. I don't think my rear speakers work now either, but then again I don't even use them anyways...
Cheap and easy way to get that clip off the window crank: Open up a paper clip, take some needle nose pliers, bend one end of the opened paper clip like a small hook. Push the door panel in to reveal the clip, use the newly designed hook to grab it and pull it out of there! Tada!
