Where exactly are the Moon Roof drain holes located, I found a hole in the channel way forward but when I try to run a line down it it just curls back under the channel rail.
The holes are in the front and rear corners of the roof pan. If you pull down the headliner on the front side you will see the hoses going into the pillars.
OK, found the front ones (bigger than I expected and have roto- rooted them and then put a little household bleach down as well. Now that I know where to look , I can find the aft ones.
