Crossover Starter
Old Sep 18, 2010 | 07:16 PM
laforge's Avatar
laforge
Default Crossover Starter
Hello Thankls in advance for all of your help. Can a starter from 1998 or 99 dodge Stratus fit in a 1999 dodge Neon
Old Sep 18, 2010 | 10:42 PM
laforge's Avatar
laforge
Default crossover starter
I had the stater check it pass test what else could it be
Old Sep 19, 2010 | 08:06 AM
sapporo's Avatar
sapporo
electrical problem.
Old Sep 19, 2010 | 03:25 PM
laforge's Avatar
laforge
Well I had the battery checked it was good the guy at advance auto said it didnt even need a charge so ther's a fuse box next to the battery the diagrham showes a big 30 amp fuse and and what I think is a starter relay no visiable damange I just dont understand the clunk sound is the starter drive going into the flywheel but it wont spin the flywheel
Old Sep 19, 2010 | 07:12 PM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Did you lock up your engine?
Old Sep 19, 2010 | 08:33 PM
sapporo's Avatar
sapporo
dead sort between the steering wheel and seat?
Old Sep 20, 2010 | 06:25 PM
laforge's Avatar
laforge
Hey Guys I figured it out thre battery cables was coroded underneath the insulation I change the cables and it started right up but what got me was that I thought it would all or nothing not just the starter drive ingaging but not spining one of thoses freak of nature things i guss
Old Sep 20, 2010 | 07:05 PM
sapporo's Avatar
sapporo
No, that's electrical cuz the big heavy wire spins the starter. and a tiny wire makes it click. you discovered and unwanted high resistance. one of the 4 common electrical problems (post #3).
great job doing some diagnosis and reporting back your findings...that'll help someone else...hopefully
