srt-4 piston questions
Old Sep 23, 2010 | 03:14 PM
TRTPLAYER's Avatar
TRTPLAYER
Default srt-4 piston questions
i was wondering if pistons and rods from a srt-4 will fit in a stock 95 dodge neon block its a sohc.
thanks
Old Sep 23, 2010 | 08:18 PM
Nuklhed074's Avatar
Nuklhed074
yes they do have the same bore so technically they will fit in the block as for rod use and such i am unsure
Old Sep 23, 2010 | 09:10 PM
TRTPLAYER's Avatar
TRTPLAYER
thanks for the info bro
Old Sep 23, 2010 | 09:15 PM
sapporo's Avatar
sapporo
check out like eagle rods or wiseco pistons. you can gather up all the dimensions (rod length and pin height) are 2 key factors you need to know.
