Still overheating..
Old Nov 18, 2010 | 10:09 AM
bg1995redneon's Avatar
bg1995redneon
Originally Posted by slammedneon
i had the same problem just did my headgasket and some little motor hop ups wile head was off butt i need to put my timing belt on and cant get this damn hermonic balancer off
Go to Autozone and borrow the Chrysler Harmonic Balancer remover tool. Use the longest rod in the box and add to it a 1/2 - 3/4 inch piece of metal that fits up inside the hole of the puller (cut a bolt if you have nothing else) to give you the extra length you need to easily remove it. You will get your money back when you return the tool.
Old Nov 18, 2010 | 03:10 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
Yes, I can't even imagine removing that pully without the proper tool
