AIR INTAKE SYSTEM!!!
Old Jun 7, 2005 | 11:52 AM
matpro's Avatar
matpro
Default AIR INTAKE SYSTEM!!!
OK Guys....
What is the best intake system for a Plymouth Neon 1997 DOCH 2.0L Car......
I was looking at Kand N...AEM.......
Are there any others....and how much....and what has the best power gain.....
Thanks[sm=helpout.gif]
Old Jun 7, 2005 | 12:52 PM
95SOHCNeon's Avatar
95SOHCNeon
Default RE: AIR INTAKE SYSTEM!!!
you could look for an iceman intake. I know K&N and AEM make them for that car too. But check into the iceman.
[sm=nxsmile.gif]
[sm=signs003.gif]
Old Jun 8, 2005 | 02:42 AM
RadarLove's Avatar
RadarLove
AEM (new style) is crap - it's a warm air intake. K&N isn't much better, just has a heat shield to make it not quite as warm.
The Iceman is nice, but pricey. You do get a new battery tray though, so installation is easy for those who don't want to think hard.
Rage makes a unit that has dynoed the same as the Iceman on most cars. Costs a little less, requires work to the battery tray (or relocation to the trunk).
Then there's the infamous "ghetto" 3.0L mod. Use the intake tube from a 3.0L V6 (like a caravan), hook it to the TB, put a filter on it, and get the same gains (dyno proven) as the iceman for a fraction of the cost.
Best of luck!
Old Jun 9, 2005 | 02:54 PM
matpro's Avatar
matpro
Like the ice man......But it made in plastic....any intakes that are Icemanstyle but in a polished metal.....???????????
Old Jun 9, 2005 | 03:48 PM
RadarLove's Avatar
RadarLove
The metals you'll find CAI's made out of conduct heat many times better than HDPE. End result is a hotter air charge with a metal piece. Hotter air means less dense air, which means less oxygen per stroke. Do you want performance or bling?
Old Jun 9, 2005 | 09:14 PM
casper's Avatar
casper
the iceman is the best set-up, it is expensive, but worth it.
Old Jun 10, 2005 | 11:40 AM
matpro's Avatar
matpro
I want performance..and bling....But i guess performance is more important....I think i will go iceman....
Anything good about the Ractive sgcn94?
I like the look but does it perform well?
Old Jun 13, 2005 | 08:28 AM
RadarLove's Avatar
RadarLove
Iceman is available in different colors at least.
Old Jun 19, 2005 | 12:33 AM
matpro's Avatar
matpro
Thanks for the help ill check out the ice man...
