Help .
Old Nov 12, 2010 | 07:16 PM
1955effie's Avatar
1955effie
Default Help .
Hi ,
I just bought a 1998 Neon with 29k on the odometer . It ran great and drove nice ( no rattles squeaks etc) . It lost power on the way home ( engine wanted to rev but it slowed down) now it has a nasty knocking sound whent it's first started and when it revs up . I know a little about cars and I checked the oil before I bought it and it was extremely clean as was the antifreeze ( no stop leak etc ) Any one ever have one like this ? I bought this for my son to drive and he's pretty discourged and I really don't blame him for being that way . Like I said it's a 29k mile car and it even smells new ...
Old Nov 13, 2010 | 11:21 AM
mopar_man1970's Avatar
mopar_man1970
it sound like it has the bottom end knock.you can geta crank kit from autozone, advance or any other part store.
Old Nov 13, 2010 | 12:00 PM
1955effie's Avatar
1955effie
Thanks ,
I wasn't driving the car home ( my son was ) and he told me that the car also would not pick up speed when he pressed on the gas pedal but it did rev up . Could this be a dirty filter issue or maybe something else ? He said it only did it once . How much of a hassle is the istalling of a crank kit ?
Old Nov 14, 2010 | 09:06 AM
mopar_man1970
you will have to pull the motor out of the car to crank kit.or you can look around your local salvage yards to get one. most of the salvage yard run there motors to see if they are any good
Old Nov 15, 2010 | 01:25 PM
bg1995redneon's Avatar
bg1995redneon
Why use a nuke when all you may need is a firecracker?
Before you go yanking and tearing down the motor, don't you think it would be a good idea to test the compression and perform a leak down test first?
Also, it is knocking in the bottom end, or is it a case of valve rattle? Does it go away when warmed up, or keep on? Does it get quieter when warmed up, or keeps on? A mechanics stethoscope can help you determine which it is if you are not sure.
Loud rattling valves means you need a good head job. Knocking motor at 29K means that someone may have run it out of oil, so if you hook up an oil pressure guage to the port for the oil pressure sending unit, you can see if you are getting good oil pressure.
Auto or manual. If slipping and its manual, you may need a new clutch. If automatic and the motor revs but the car does not accelerate, then you may have a tranny problem.
Private sale or from a lot? If its from a lot, I hope your state has laws that can help you return a lemon. If it was a AS IS sale, my condolences.
Old Nov 16, 2010 | 07:07 PM
1955effie's Avatar
1955effie
It is a rod knock ,there is metal showing on the dipstick . I still have no idea why it let go . I ran a carfax and everything comes back as stated . 29 K Miles and one owner for 12 yrs and 4 months so who knows .
Old Nov 17, 2010 | 10:18 AM
bg1995redneon
Rebuild motor time. Sorry.
