97 wont start
Old Nov 14, 2010 | 04:21 PM
flgators's Avatar
flgators
Default 97 wont start
I have a 97 neon that will not start. I have replaced the battery and starter on the car. When I turn the key I get a thump sound and the engine does not want to start. All the gauges work but still nothing. Please help, thank you.
Old Nov 14, 2010 | 05:20 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
try turning the engine over by hand, sounds like it may be seized. you can turn it over by removing all the spark plugs and then the passenger tire and then the splash guard. the pully you see is directly connected to the crank shaft. use an extension and a breaker bar and turn it clockwise. Go easy it should turn with little effort.
Old Nov 15, 2010 | 01:48 PM
flgators's Avatar
flgators
Ok, just tried that and nothing. Could it just be a relay switch?
Old Nov 15, 2010 | 05:26 PM
bg1995redneon's Avatar
bg1995redneon
When you try to crank the motor, you say you hear a thump. Is that in addition to the sounds of the motor turning over "trying" to start?
If it is turning over, then you need to check to see if fuel is getting to the fuel rail, and spark getting to the plugs.
For fuel, get a fuel pressure tester (borrow one) and see what your reading is there.
For sparks, get an inline spark tester.
Old Nov 15, 2010 | 08:38 PM
DOHCgarrett t3
check to make sure the connections are tight on the starter. fuel pressure should be at 49 psi. then check for spark.
