check engine light
Old Nov 16, 2010 | 04:24 PM
ohioguru's Avatar
ohioguru
Default check engine light
what is the key sequence to blink the check engine light? i forgot how to do it. so if someone could run me through it again it would be sweet
Old Nov 17, 2010 | 10:17 AM
bg1995redneon's Avatar
bg1995redneon
: My Check Engine Light (CEL) is on, what do I do?
A: To read any codes on your neon, put the key in the ignition and cycle it to ACC on-off-on-off-on within 5 seconds. As the CEL flashes, count the number of flashes. This represents the code. An example would be flash-flash-flash-flash, pause, flash-flash-flash, which would be a Code 43, single or multiple cylinder misfire. A list of codes can be found HERE or HERE.
