99 neon wont start
Old Nov 21, 2010 | 02:44 PM
jimmy83's Avatar
jimmy83
Unhappy 99 neon wont start
hi im jimmy
i have a 99 neon i had timing belt changed 6mths ago and it ran great 4weeks ago it died and wont start again ive changed fuel pump, cam shaft senor, coil, battery, starter and the asd relay. The car turns over like it wants to start but doesnt. there is fuel coming so i know its not anything to deal with fuel today i pulled the wires and checked to see if there was any spark which i got nun at all from any of the 4 wires. so i thought i just got a bad coil took it back to autozone and got a new one put it on and it still wont start. so a neighbour check the wires powering the coil and there is no power to run the coil can any1 plzzzz help why is there no power runing to my coils and could this be the reason my car wont start or could it be my timing belt agian
Old Nov 21, 2010 | 03:13 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the first generation Neon section,
FF
Old Nov 22, 2010 | 01:15 AM
schroetter2011's Avatar
schroetter2011
it definitely sounds like the no spark would be your issue. id get that looked at first
Old Nov 22, 2010 | 02:22 AM
93tona's Avatar
93tona
did you check all the wires to ur 02 sensors for bare spots
look under back seet for bare spots on wires there those run to the fuel pump
did you do the of on key codes what do they say
lol i think your neon expired please dispose of safely mine is doing the same thing but i have spark and fuel 5 mechs all stumped and no one on here has any help for me either im thinking i just hit my expiration date lol
Old Nov 22, 2010 | 11:43 AM
jimmy83's Avatar
jimmy83
yesterday afternoon i checked the timing again and its set right the wires that feed the power to the coil has no power running to it and theres no codes when i hook a dig. computer to it when i ran wires stright from the battery to the coil it started for abour 30 mins but now thats not starting the car
Old Nov 22, 2010 | 11:45 AM
jimmy83's Avatar
jimmy83
also i did check the wire harness feeding the coil to make sure they are not damged and they are perfect i just can not find out why theres no power to the coil the coil itself works great i even put it in my wifes neon to see and it ran hers perfect
Old Nov 22, 2010 | 01:18 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
what about the crank sensor?
Old Nov 22, 2010 | 08:19 PM
Ghost Neon 2's Avatar
Ghost Neon 2
Have you checked for spark?
Have you swapped out the pcm with a known working unit?
PS- You may want to invest in factory service manual after this. Consult ebay.
