1996 Dodge neon motor swap
Old Nov 22, 2010 | 12:53 AM
schroetter2011's Avatar
schroetter2011
Default 1996 Dodge neon motor swap
Hello, i have a 1996 dodge neon with an SOHC engine. I recently spun a berring in my block and i was wondering if a DOHC engine would basically drop right into it. If not i'm going to need a list of what i'm going to need.
Here are a few questions i have.
Will my exhaust manifold on my sohc engine bolt up to a dohc engine?
Will my intake manifold on my sohc engine bolt up to a dohc engine?
Will i need a different ECU?
Will i need different motor mounts?
Will i need a different transmission?
PLEASE REPLY WITH 100% HONESTY
THANKS!
Old Nov 22, 2010 | 02:17 AM
93tona's Avatar
93tona
exhaust im not sure but i think so
intake no you need a metal one
no new ecu
motor mounts no
transmission no
when you grab the DOHC grab the whole wiring harness and youll be fine drops right in
Old Nov 22, 2010 | 07:31 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
you will need the ECU or you will run lean. exhaust manifold, intake manifold.
