1998 Cluster or board
Old Nov 29, 2010 | 05:16 PM
lionfish37's Avatar
lionfish37
Default 1998 Cluster or board
Can you buy a new board anywhere for these? It is the issue and I can't fix it myself with the soder iron. Or a used cluster? only two on ebay.
Old Nov 29, 2010 | 09:38 PM
DOHCgarrett t3's Avatar
DOHCgarrett t3
what is wrong with it that you can not fix it with the solder? I think myself I would just buy a new cluster if i could not solder it. and you can swap out the odometer
Old Nov 29, 2010 | 09:59 PM
lionfish37's Avatar
lionfish37
I google'd and can 't find any new ones. I found a used one on ebay. I have poor vision that's why.
Scott
Old Nov 30, 2010 | 11:09 AM
bg1995redneon's Avatar
bg1995redneon
Scott
Sorry about your visiion issues. But if you search an online junkyard engine (such as: http://www.car-part.com), you can find a bunch of them.
BTW, you need to keep all issues on a particular issue on a single thread (in your case, you have two threads both talking about your IC, and you only need one). It helps others keep track of who has suggested what and when, and if you break it into multiple threads, it gets harder to see the history.
