Weather Strip Performance????
Old Jun 12, 2005 | 06:14 PM
95neonracer's Avatar
95neonracer
Default Weather Strip Performance????
I was reading up on some intake performance, and i heard that if you simply remove the weatherstrip along the windshield and the engine bay you gain 1+ hp. Is this true? Nothing I think is even worth doing, but i was just curious. They say it lets more air get in along the intake area.
Old Jun 12, 2005 | 06:56 PM
tchase's Avatar
tchase
Default RE: Weather Strip Performance????
I've also read the same thing somewhere. I think it would depend on you particular airbox/intake setup to some degree, but regardless if your intake is at the rear of the engine compartment this will allow it to get more air as well as letting out some excess heat I assume. Either way it's about a 30sec mod, it just slides off. You don't even have to remove the stripping from the engine bay it will rest quite nicely just below it's original location. Try it out and see if you notice a difference. I personally haven't experenced any problems running with it off, but watch out for moisture issues.
Old Jun 13, 2005 | 08:56 AM
RadarLove's Avatar
RadarLove
It allows heat to leave the engine bay faster, reducing underhood temps. The temp is reduced enough to see a 1 HP gain, dyno proven.
Old Jun 14, 2005 | 07:35 PM
95neonracer
Wow it even shows up on dyno?? Thats not bad
Old Jun 15, 2005 | 11:37 AM
SlowAssNeon's Avatar
SlowAssNeon
yes, removing the weatherstripping there has been shown to have a 1hp gain.
i should also note, that i could run on the dyno multiple times, and have a 1hp gain from run to run as well.. so im not real sure that 1hp gain from the weatherstripping is actually a gain, or just a variance from run to run.
Old Jun 15, 2005 | 01:23 PM
highrevr/tflea's Avatar
highrevr/tflea
GOOD TO SEE ya on here again slowass where ya been the past few weeks?!!!!!!!!!
Old Jun 15, 2005 | 09:53 PM
casper's Avatar
casper
It may or may not work, but it can't hurt and will reduce the temp a little.
Old Jun 17, 2005 | 04:41 PM
95neonracer
I took it off, drove around for a few minutes and when i got back home i immediatly put it back on. The only thing it seems to do is make your car look uglier. lol
Old Jun 18, 2005 | 07:17 AM
RadarLove's Avatar
RadarLove
We're talking about the rubber strip on the cowl, not the cowl itself... Been so long since mine was on, but I didn't think it was even visible unless you really looked for it.
