Tach Help
Old Dec 31, 2010 | 11:10 PM
SOHC's Avatar
SOHC
Default Tach Help
I installed a tach in me 1995 SOHC neon i got from a guy. He took it out of a truck because he didnt like the big 5inch racing tachs. Anyway I got the tach hooked up and it worked. I turned the **** to set the shift light now every time i cut the key on and start the car it goes up to the shift point and thats it. Any ideas its a autometer autogage
Old Dec 31, 2010 | 11:49 PM
hemi4spd's Avatar
hemi4spd
maybe he didnt like big 5inch racing tachs,
that dont work? lol
probably got something to do with when you set the shift points as it started doing this after that
need model number as ther are about 5 autometer autogague tachs.
does it have memory and/or playback?
hell go here for a PDF. manual for it
http://www.egauges.com/AM_Instr.asp#Tachometers
Old Jan 1, 2011 | 11:22 AM
SOHC's Avatar
SOHC
no just a **** to set the shift point it was working when i hooked it up then i turned the **** while the car was running
