oil on plugs
Old Jun 16, 2005 | 05:15 AM
xdeathwishx's Avatar
xdeathwishx
Default oil on plugs
Ok, i have oil mixing with my coolant. I know thats a sign of a bad HG. What about oil on the tops and threads of the spark plugs. Is that also a sign of a bad HG? could it be anything else that's easier to fix? If i do need a new one, where would i get a new HG, and how much does it normally cost to get it replaced. How hard is it to replace yourself? Where can I get instructions on how to do it?
Old Jun 16, 2005 | 10:58 AM
casper's Avatar
casper
Default RE: oil on plugs
I would have to say that it is most likely a head gasket. If you are getting oil on the plugs and in the spark plug tubes that is a different problem. That is either the spark plug tubes, but more likely the seals at the bottom of the tubes.
Old Jun 16, 2005 | 03:58 PM
xdeathwishx
when i do the head gasket, what all should be replaced, other than the HG, the valve cover gasket, and all the seals around the spark plugs? How do i set the timing once i get it all back together?
Old Jun 16, 2005 | 10:09 PM
casper's Avatar
casper
I would also do the timing belt and water pump while you are there. There are timing marks that you use to set the timing.
Old Jun 17, 2005 | 12:41 AM
catman22's Avatar
catman22
timing belt tensioner pulley too when doing a timing belt, costs about 50 - 60 bucks but well worth it in the long run.
Old Jun 17, 2005 | 03:14 PM
xdeathwishx
Do I have to remove the cam angle sensor when i do this? Im replacing the cam seals too... If i remove the sensor, is it reall hard to line it up right when i put it back on?
