New Brakes
Old Jun 19, 2005 | 06:17 AM
decker87's Avatar
decker87
Default New Brakes
After nearly killing two deer in teh road a few days ago, I realized that maybe it is time that I got better brakes. Mine are not that good, but if I'm going to upgrade them I'd rather get aftermarket brakes than just repair whatevers wrong with the current ones. Are there any suggestions you guys have, for a guy who likes to floor it between stop-signs?
Old Jun 19, 2005 | 01:13 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: New Brakes
well if your goin to keep stock rotors and you have all around disc breaks, autozone sells these gold brake pads that I have on mine that even after 30000 miles still show little wear and Im a heavy breaker so id look into those. Good idea to replace the rotors tho if they show pitting and signs of warping...
Old Jun 19, 2005 | 07:38 PM
casper's Avatar
casper
I have the power-stop slotted and dimpled rotors and hawk pads, they are great, much better than stock.
Old Mar 10, 2006 | 01:16 PM
streetbikr600's Avatar
streetbikr600
hey i got the same exact combo hawk pad with power slot rotors.. when i put in the two mounting bolts they went in with a fight...now when i spot only the center of the dics has wear on it. the rotors are getting way to hot i think some thing maybe uneaven or sumtin. i would like some help a lot i would appreicate it....i hope u guys kinda noe wat i am trying to say here..
Old Mar 10, 2006 | 02:27 PM
Noizemaker's Avatar
Noizemaker
I'm with the guys above.
Hawk HPS or HP+ depending on how much squeal you can stand and some OE replacement rotors, plus a brake bleed with some good fluid and you're good to go. You'll be WORLDS better, and probably only 100 dollars poorer depending on how much rotor you buy.
