jumping gauges
Old Feb 5, 2011 | 07:30 PM
dafullmonty's Avatar
dafullmonty
Default jumping gauges
Hi has anyone experienced the guages workin and then not and then they do? is this an easy fix or do i get to burn the 99? lmao
Old Feb 5, 2011 | 10:42 PM
Ghost Neon 2's Avatar
Ghost Neon 2
http://www.youtube.com/watch?v=CtwnsPmkX1M
Old Feb 5, 2011 | 11:04 PM
NeonimusPrime's Avatar
NeonimusPrime
^^^ What he said, and it's quite common on our cars.
And it's an easy fix.
Old Feb 6, 2011 | 08:48 PM
ohioguru's Avatar
ohioguru
i have this now but im just wondering......if it fails isnt it true that you have to just replace the cluster then?
Old Feb 7, 2011 | 04:41 AM
NeonimusPrime
Very true, and it's a simple plug and play.
The only thing is your millage won't be the same, and you could inherit the same problem from a junker cluster.
Old Feb 7, 2011 | 09:34 AM
bg1995redneon's Avatar
bg1995redneon
If you change out the odo with yours, your mileage will still be accurate. 1st gen neons use a mechanical odo and it is interchangable. You need a T9 torx bit to get it off.
Old Feb 8, 2011 | 05:52 AM
NeonimusPrime
Very good point, I never thought about actually taking the cluster apart to change that, but I can see now, it wouldn't be that hard.
Thanks for the tip!
