Oil Leak Problem
Alright once again another problem, this time a pesky oil leak. Its going thru like crazy, about 1 quart ever 20-30 miles. Car does not overheat so can i eliminate head gasket from the scenarios? I havent had a chance yet the last few days to jack it up since its been snowing. Tons of oil on the oil pan along with it spread across the underbody of the motor, possibly from wind? Someone please help me with some pointers, 1st time ever haveing this problem and not sure what im looking for. thanks
well what i would do first is take it to a coin operated car wash and soak the engine bay down with tire cleaner from top and the bottom side side, prettymuch everywhere possable. Leave the engine running and dont worry about the electrical coil or anything like that. I have sprayed down mine plenty of times. then you can further localize where the leak is comming from.
With that much of a leak (1qt per 20-30 miles) you have to have a really bad seal leak. The rear main seal or head gasket which is a notorious problem on 2.0 SOHC neon engines. The oil feed circuit for the head is in the driver side rear corner and dumps tons of oil down the back of the motor when it fails. But I also hear a lot about these motors puking rear main seals out.
