1998 2.0 sohc 5 speed timing off please help
Old Mar 1, 2011 | 08:36 PM
rickrick78's Avatar
rickrick78
Question 1998 2.0 sohc 5 speed timing off please help
i replaced cam seal ,crank sensor,cam sensor, starter,battery, plugs and wires tdc timing and marks lined up go to crank and wont start ,i have spark, fuel, compression,and blows smoke out the throttle body when trying to start .............help
Old Mar 2, 2011 | 07:41 AM
DOHCgarrett t3's Avatar
DOHCgarrett t3
recheck your timing marks. when you were replacing the belt you should have had the crank one tooth before TDC and route the belt from bottom to top with the tensioner last.
