400hp turbo 420A Problem
Old Jun 25, 2005 | 11:19 AM
Mopar RS's Avatar
Mopar RS
Default 400hp turbo 420A Problem
I have a 420A with 400hp in the wheel at 19psi. I install a Center Force clutch but is not working. Clutch Master have one but its very expensive $800.00. I think the Unorthodox clutch its not very strong. Somebody know another company that make this clutch for this engine.
Another Question, you know everybody call this clutch's the "hamburger" (flywheel, disc and plate, all in one). Theres some clutch of other car that i can switch to my engine. I really want to install ACT, you know, plate apart, disc apart, if i need to do some invent. Please let me know.
Old Jun 25, 2005 | 01:03 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: 400hp turbo 420A Problem
ACT Makes the clutch your prolly lookin for, Xtreme pressure plate, high heat sintered iron plate teeth, throwout bearing, puck disc, I have the same one in my sr20 sentra and act disc in my neon they are both very good clutches fidanza makes some of the best flywheels for the money, id go with them.
Old Jun 25, 2005 | 01:29 PM
Mopar RS's Avatar
Mopar RS
I go to ACT Clutch but the available its to a 4cyl 2400cc, 225mm and my engine its 2.0lt. Its the same clutch?
Old Jun 26, 2005 | 04:43 PM
highrevr/tflea
yeah i would think its the same...just cuz u add turbo doesnt make difference. Unless in terms it has a certain torque rating in which act is built for it. You should also upgrade your CV axles if u havent yet cuz it lays 300% more torque to you wheels. Ill call my vendor to see if the ACT xtreme clutch is at cost and maybe you can get it cheaper. My cost when i bought the whole s/u was like $200.00 mark ups are usually higher. Ebay might be a god source as well.
