TURBO NEON NOT STARTING!
Old Jul 17, 2005 | 10:36 PM
casper's Avatar
casper
Default RE: TURBO NEON NOT STARTING!
Try a junk-yard.
Old Aug 10, 2005 | 10:06 AM
R34TuRbOnEoNbOy's Avatar
R34TuRbOnEoNbOy
No still havent fixed it...
Old Aug 10, 2005 | 10:09 AM
R34TuRbOnEoNbOy
when i went to go start the thing it just turns and turns....i come to find out that the crankshaft sensor connector had its wires pulled out so i put a new connector on sensor so it should be good... but it still is not starting...I did a voltage test on the coil and i am not getting any voltage into the coil.....need help i have been workin on this car for like the last two months and im starting to get mad!!! Its my turbo neon and I miss the speed....need help..I have a car show in two weeks and have to drive it there...so i dont care if you are just guessing, just throw any idea at me..thanks
Old Aug 10, 2005 | 10:10 AM
R34TuRbOnEoNbOy
New update..ok so i went out to car and started to mess with it... I check the fuses again...come to find out that the fuel pump fuse is blown so with the key on i put a new fuse it.....the car buzzs with sound of fuel pump....then when i goto start car the fuse pops....wtf!!!!!!! this doesnt make much sence to me considering that im not hacing fuel probelms im haveing ignition problems.
Ok to make it a little easyer on you helping me...i think it has something to do with me putting a new starter on my car....what could I have done to make it do this?
Old Aug 10, 2005 | 04:35 PM
streetbikr600's Avatar
streetbikr600
this might sound real weird but check all the grounds such as fuel pump oil sensor and mass flow sensor.i had a street bike once and it did the same thing and the fuel peump was not grounded because i shorted it out buy doing the same thing as u.buy shortign one thing out it messed some thing else like a dome like or cig. lighter
