96 neon help!
Old Jun 28, 2005 | 05:27 AM
guru2005's Avatar
guru2005
Default 96 neon help!
i bought my 1996 dodge neon highline 6 months ago and the problems have started to roll in. when i drive for about 20-30 minutes ALL of my gauges stop working. when im at a stoplight or with the car on but no movement, it smokes bad when i take off.. it seems to burn alot of oil. i only paid $1300 for it so i dont know if i should just sell it or what.. what do you think?
Old Jun 28, 2005 | 11:36 AM
catman22's Avatar
catman22
Default RE: 96 neon help!
as far as the gauges go, check the stick at the top of the page for first gen gauge cluster repair, that might be your problem. do a compression check on the car and it will tell you what kind of shape your head gasket is in, and the burning of oil might be a bad head gasket or bad spark plug tube seals.
general info cylinder compression pressure
standard 170 to 225 psi
service limit 100 psi
difference between cylanders 25%
