Error Code 44
Old Apr 6, 2011 | 12:30 PM
jficarra3's Avatar
jficarra3
Default Error Code 44
Did the key dance today and found Error codes 12, 44, 55. I know about the 1st and last codes... but AutoZone, Advanced Auto, and the dealer couldn't tell me a thing about Code 44. Error Code 44 reads: Battery Temp Sensor Volts Out of Range. Any ideas???
Old Apr 6, 2011 | 01:13 PM
bg1995redneon's Avatar
bg1995redneon
The most likely senario is that your battery temp sensor (located in the battery box) is either cracked and broken, or the wires/connector to the sensor is cracked/corroded and not making good contact or is shorting out.
A new sensor is about $11.
Old Apr 9, 2011 | 03:32 PM
jficarra3's Avatar
jficarra3
Went to Autozone, Advance Auto Parts, and the Dodge dealer and NO ONE can get the part. So I looked under the hood to find this thing and see what it would take to get one out of a car at the JY. Come to find out this stupid thing wasn't even plugged in!!! Connecter was a little corroded so I used some De-Ox-It on it to clean it up and plugged it in and TADA! Error code went away and dash light went off.
Old Apr 11, 2011 | 03:00 PM
bg1995redneon
Glad you did not need a new one but if you did, you can find one at rockauto.com. I selected the 1998 Dodge Neon SOHC but the part is the same for most models (except 1995 with different connector/pins).
Battery Temperature Sensor - Standard Motor Products - Part # TS405 - #5269742 = $11.42.
