95 crankshaft sensor replacement problem....
Old Apr 9, 2011 | 09:21 PM
dino11's Avatar
dino11
Default 95 crankshaft sensor replacement problem....
i have an early model neon that i am changing the crank sensor on. the original had the round pins, the replacements have flat pins. the first replacement sensor i bought didnt come with a pigtail harness, and i of course tried to do it myself, boogered it up...
the second crank sensor came from napa and had the pigtail included... however at some point i got the wires backwards or sideways or just not in order...
my question is - i have 3 wires from the cars harness ORANGE, GREY w/GREEN STRIPE, GREY w/BLUE STRIPE... the pigtail harness and the original wires dont match... SO in what order do the original wires go into the clip? holding the clip so that the wires are facing UP( as it would be if it was mounted) what are the order of the wires?
Plz help.... and many thanks
Old Apr 11, 2011 | 09:19 PM
dino11's Avatar
dino11
bump^
