SOHC motor
Old Jun 14, 2011 | 04:35 PM
wfo6's Avatar
wfo6
Default SOHC motor
Iv got a 95 SOHC. Was lookin to put the DOHC pistions in it to jump the compression up. The question I got is am I gonna run into valve clearance issues since those pistons are domed? Thanks for the help if anyone does?
Old Jun 14, 2011 | 05:05 PM
Dazzellerr's Avatar
Dazzellerr
I do not think so. The blocks are the same, you might, just for piece of mind, take the head down and check it for how far it has been decked. If it is decked too far, it might have issues with the pistons.
Old Jun 15, 2011 | 11:25 AM
wfo6's Avatar
wfo6
Ok thanks...how about any cam ideas? And with puttin a biger cam in would I run into any clearance issues there as well?
Old Jun 15, 2011 | 02:44 PM
bg1995redneon's Avatar
bg1995redneon
Actually the 1995 cam for the SOHC engine is something subsequent year SOHC'ers want to get because it was more agressive then later years, so my advice is keep it.
Old Jun 16, 2011 | 02:06 PM
Dazzellerr's Avatar
Dazzellerr
Yes, if you are going the budget route, then get a 95 cam. If you want something bigger, OS valves and a crane 16 or 18 would be good.
Old Jun 17, 2011 | 12:41 PM
wfo6's Avatar
wfo6
Ok great. Also I heard that the neons that have the DOHC 5spd have a locker in the trany that kicks in at 35mph. Is this true? If so I just bought a 96 avenger SE that has the DOHC in it with a 5spd. Runs. Drives. Not a bad deal. Only 120000 miles on it
Old Jun 17, 2011 | 06:43 PM
Dazzellerr's Avatar
Dazzellerr
Not true, only difference is gear ratio's, 3.55 or 3.94.
