ECU
Old Jul 12, 2005 | 05:27 AM
Macloed's Avatar
Macloed
Default ECU
Hi All... My 98 Neon Automatic SOHC needs a new ECU Are can i use any year from 95-99 for it... Also are there any AfterMarkets you can suggest.
MAC
Old Jul 12, 2005 | 12:54 PM
chud298's Avatar
chud298
Default RE: ECU
ORIGINAL: Macloed
MAC
I'm pretty positive they are all the same...and yes mopar makes an aftermarket ECU, I have it but I'd only suggest getting it if you decide to do some major mods.
Old Jul 12, 2005 | 06:16 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: ECU
I dont think the 95 and 96 ecu will work for it...I could be wrong tho.
Old Jul 17, 2005 | 10:11 AM
RadarLove's Avatar
RadarLove
Default RE: ECU
'95 will not physically fit, '96 will not work (rad fan pinout location). Have to use one from an auto unless you hook up a way to activate torque converter lockup and/or run an external oil cooler. Mopar Performance PCM's do not support automatics. AFX does, but more expensive.
Best of luck!
