electical problem on 1999 dodge neon
Old Jun 28, 2011 | 10:05 PM
racerx80p's Avatar
racerx80p
Default electical problem on 1999 dodge neon
i just bought a 1999 doge neon 2.0 dohc it will roll over but wont start have power to computer injectors ing.coil, crank sensor have fuel in tank andfuel pump works. i was told to check the asd relay all has power. timing belt is in tacked and rolls with the motor. if anybody has any ideas im willing to listen to you.
Old Jun 29, 2011 | 10:15 AM
das2123's Avatar
das2123
Have you checked fuel your fuel pressure? Should be 49 psi. What about spark plugs? Any codes?
Old Jun 29, 2011 | 09:47 PM
racerx80p's Avatar
racerx80p
Default electrical problems
i have 60 pounds fuel pressure,new plugs no codes
Old Jun 30, 2011 | 12:09 AM
Dodge Tech's Avatar
Dodge Tech
check for spark then at the plugs
Old Jun 30, 2011 | 09:08 AM
das2123's Avatar
das2123
Do the key dance and see if any codes pop up.
Old Jul 1, 2011 | 07:07 AM
racerx80p's Avatar
racerx80p
Post electrical problem 99 dodge neon
lined up timing marks yesterday tdc everything checks out there i have power at conector at ing, coil ill check for spark today. somebody told me to change crankshaft sensor im going to try that too today. thanks all for imput.
Old Jul 1, 2011 | 10:38 AM
Dodge Tech's Avatar
Dodge Tech
Dont change anything untill u know what u are missing by u changing stuff on the wim U add into the factor of human error and also cheap or damaged parts
Old Jul 2, 2011 | 10:32 AM
racerx80p's Avatar
racerx80p
Unhappy electical problem 1999 dodge neon
im baffled whythis car dont start im in the process of tracing wires i been chasing this problem for 2 weeks now
