'99 Neon Gas Cover/Check Engine Light
Old Jun 30, 2011 | 04:46 PM
nyneon's Avatar
nyneon
Default '99 Neon Gas Cover/Check Engine Light
Recently my mechanic hooked his meter/computer up to my car and discovered 2 things that were making the light come. The exhaust leak he fixed, and he told me that the gas cover (original) was making the light go on. I went to the local Advanced Auto Parts and bought a Stant 10817 gas cover (for Neons made before Dec. 1998. Mine was made in Aug.'98). I took it home and put it on and drove around, and the light stayed on.
Is there a better replacement gas cover for a 1999 Neon SOHC 2.OL? Thanks.
Old Jun 30, 2011 | 06:11 PM
Dodge Tech's Avatar
Dodge Tech
need to know what the code is for the check engine light
Old Jul 1, 2011 | 09:14 AM
das2123's Avatar
das2123
I have not heard of the gas cap being loose to cause the CEL to come on in a neon. Please get the codes. You can do the key dance and pull the codes yourself.
Old Jul 1, 2011 | 02:42 PM
nyneon's Avatar
nyneon
I got it off. I disconnected the negative cable on my battery for 30 seconds, then reattached it. It cleared the Check Engine Light.I know it was caused by the gas cover, so I didn't need to know the code. Besides, my mechanic read the code and told me just what it was. Thanks.
Old Jul 1, 2011 | 02:53 PM
das2123's Avatar
das2123
OK, so you didn't reset the PCM yet. Good deal. We'll see if it comes back on after 50-100 miles of driving. I have driven over a month without a gas cap and never threw a code.
Old Jul 1, 2011 | 09:53 PM
Dodge Tech's Avatar
Dodge Tech
that was a waste of time it will more then likely come back on all U do when u do that sorta stuff is make it that much harder to find the real issue at hand.
