97 SOHC M/T Can't Select Reverse
Old Jul 6, 2011 | 10:22 AM
KC0EZP-'s Avatar
KC0EZP-
Default 97 SOHC M/T Can't Select Reverse
My wife drives a manual 97 Neon and the transmission will no longer go into reverse and it feels like something is blocking it. All 5 forward gears are working fine. The shift linkage bushings on the transaxle side are shot, gone even, but I can't even select reverse by manually manipulating the cables.
Sometime when I pull the selector down from fifth to reverse it fells like it catches on something. I can then swing the selector from right to left but I won't go down any further. When I release pressure I can hear a slight click and then I can move the selector down into second or fourth.
Any more ideas before I have to have the tranny pulled?
Thank you,
Jason
Old Jul 6, 2011 | 06:32 PM
das2123's Avatar
das2123
It could be the bushing on the side of the shifter. They go bad and rot out as well. Pull the console out and have a look. I had one of the bushings fall off on me while driving and had to stay in second gear all the way home.
If they are bad, try http://www.boogerracing.com/ for some new bushings. They are high quality and reasonably priced.
