Overheating Woes
Old Jul 4, 2011 | 01:45 PM
laforge's Avatar
laforge
Default Overheating Woes
Hello to all and thanks in advance for the help. I've got 2 problems My daughter's car is a 1999 dodge neon DOHC Problem#1 a leak in the coolant resvior was able to remove the hold down screws but ther is no clearance to remove the coolant tank, Problem#2 what is the correct metric or standard size socket to remove the coolant temp sensor we whent to auto zone we pulled code (PO 118) = coolant temp sensor
Old Jul 6, 2011 | 06:36 PM
das2123's Avatar
das2123
I am not sure on the size of the CTS socket. The reservoir can be challenging to remove with the power steering and AC stuff in the way. Is there any room to possibly drop it out of the bottom of the engine bay?
Old Jul 7, 2011 | 03:32 PM
bg1995redneon's Avatar
bg1995redneon
As for problem #1, you can unbolt and shift the PS reservoir out of the way to get it out, or do as das stated and drop it out the bottom.
As for problem #2, you need a deep well socket to remove the sensor. the deeper the better. I do not remember what is the correct metric size, but I believe it is 18 or 19mm. Everything on the car is metric. No SAE.
PS. check the wires and connector to make sure there are no shorts/cracks, etc before you replace it. You may just have a bad/dirty connection.
