Need Help Bad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Jul 13, 2005 | 10:21 PM
neon1985's Avatar
neon1985
Default Need Help Bad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Does anyone know exactly what it means to make modifications to the wiring harness? does it mean just having to extend some wires or is more complicated then that?
Old Jul 18, 2005 | 05:26 PM
matpro's Avatar
matpro
Default RE: Need Help Bad!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
What do you mean make modifications ?
Old Jul 20, 2005 | 04:15 AM
casper's Avatar
casper
modifications to the wiring harness can be anything from cutting into it to connect a wire to rewiring the car. What product is it that you are asking about?
Old Jul 21, 2005 | 06:59 PM
neon1985's Avatar
neon1985
nothing much i was switching a 96 sohc to a dohc 98 and was wondering if all the wiring stayed the same?
Old Jul 25, 2005 | 07:25 AM
RadarLove's Avatar
RadarLove
The only thing that sticks out that I recall is the coolant temp sensor wire will have to be extended (SOHC on the back of the head, DOHC over by the thermostat). Use a '96 PCM if you are using a '96 wiring harness or you'll have issues with the fans.
Best of luck!
Old Jul 31, 2005 | 10:17 PM
neon1985's Avatar
neon1985
yeah but will a 96 sohc ecu run a 98 dohc neon i mean i can change out the fans that's no big dealbut in terms of gear ratios which of the two is better both are automatics.
Old Aug 3, 2005 | 08:57 AM
RadarLove's Avatar
RadarLove
It's not changing out the fans, it's changin the pin location on the wiring harness where it connects ot the PCM. That's the only pin that's different.
Yes, a '96 PCM will run a DOHC engine, but it will run like crap because the fuel and timing curves are seriously retarded (in more ways than one...). You're much better off using a dohc PCM that came from the same year as the wiring harness.
There is no difference in gearing. It's the same automatic that was used in the Omni...
