Starter Relay Ground
Old Jul 13, 2011 | 01:59 PM
cereeal's Avatar
cereeal
Default Starter Relay Ground
The ground connection on my starter relay gives me a good ground when my key is in the off position, but when I put it the key in any other position I only get 3V passing through, like there's some type of resistance. This is obviously stopping me from starter my car properly, so right now I just have a wire going from the relay to the negative on the battery because I'm pretty confident I can do without the P/N switch. Also, I replaced the switch and I'm still having the same problem.
Any help would be appreciated.
Old Jul 15, 2011 | 09:03 PM
ohioguru's Avatar
ohioguru
did you check the wire for cuts? possible spark jump can happen when you throw more voltage through it.
