SRT 4 Sway bar
Old Jul 19, 2011 | 09:16 PM
DNeon's Avatar
DNeon
Default SRT 4 Sway bar
Hey guys, I was just wondering if the SRT 4 sway bars (front and back) fit on our 1g neons? I was searching the forums to find the answer but cant find anything.
If they do fit, the upgraded thicker sway bars should b fine too right?
Old Jul 21, 2011 | 09:41 AM
das2123's Avatar
das2123
No it will not, different size. You can use any sway bar from a first gen neon.
Old Jul 21, 2011 | 06:18 PM
DNeon's Avatar
DNeon
Is it just different size? or does it route differently, cause if its just thicker cant you get the bracket and bushing for that size?
Old Jul 21, 2011 | 08:58 PM
das2123's Avatar
das2123
The problem is its wider than a 1st gen neon. It can work, but you would have to fab up some end links and not worth it in my opinion as the SRT-4 sway bar is 17mm and the 1st gens are 16mm. 2nd gen R/Ts have 19mm sway bars, but again they are wider.
Old Aug 1, 2011 | 11:02 AM
DNeon's Avatar
DNeon
thanx Das, I'm just looking into upgrading my suspension and brakes. I wanted to get thicker sway bars and was looking into the hotchkis sway bars for the srt4
Old Aug 1, 2011 | 11:40 AM
das2123's Avatar
das2123
For the brakes, just upgrade your pads to Hawk pads. They work great. Here you go for the sway bar...
http://cgi.ebay.com/ebaymotors/EIBAC...Q5fAccessories
