overheating and no a/c
Old Jul 27, 2011 | 08:55 PM
95neon1025's Avatar
95neon1025
Default overheating and no a/c
ok so im back on the forums. i got ahold of a 1998 neon SOHC 5 speed. Anyways the car is having a bad over heating problem, i drove from ft hood to houston (3 hour drive) then drove to Arlington (6hour drive) and it didn't overheat until like 5 min from home. Whenever the a/c kicks on it overheats and when it turns on it cools down, besides the weep hole how can i know the water pump is going out? and if anyone else has any other ideas let me know
Old Jul 27, 2011 | 09:41 PM
das2123's Avatar
das2123
Have you checked the coolant level? When was the last time it was flushed and clean coolant added? Also, make sure all the air is out of the system. The water pump, idler pulley and timing belt should all be changed every 100,000 miles.
Old Jul 28, 2011 | 08:20 AM
95neon1025's Avatar
95neon1025
found out my overflow bottle is melted and is losing coolant. problem solved. thanx guys
Old Jul 28, 2011 | 09:36 AM
das2123's Avatar
das2123
I love it when it's something simple like that. Good to hear all is well.
