Misfires,
Old Aug 4, 2011 | 09:16 AM
ampb5's Avatar
ampb5
Default Misfires,
So my daughters 99 DOHC throws misfire codes, mostly happens at higher speeds. I've done the plugs, wires, cam sensor, crank sensor, coil, did a major PM a year and a half ago, took the intake off, had the injectors rehabed (Injector Rehab.com nice job with before and after charts), fuel rail looked clean, rinsed and blown out. What's left? PCM?
Old Aug 4, 2011 | 11:30 AM
das2123's Avatar
das2123
What are the codes?
Old Aug 5, 2011 | 08:41 PM
ampb5's Avatar
ampb5
Default Misfires
p0303,p0302,p0301, Random misfires
Old Aug 5, 2011 | 09:04 PM
steak59's Avatar
steak59
You are getting Mis-fire pretty much at all cylinder?
maybe it jumped time? you got ur Timing belt done yet?
Old Aug 15, 2011 | 08:13 PM
ampb5's Avatar
ampb5
Default misfires
have checked the belt, all is inorder
Old Aug 17, 2011 | 03:33 AM
smokey_1's Avatar
smokey_1
your timing might still b off thts the only thing i can think off are all the point matching up?
Old Mar 12, 2012 | 11:16 AM
ampb5's Avatar
ampb5
Default Misfire
As I don't have 100% asurity on that Next time I get the car I'll triple check
Old Mar 12, 2012 | 08:43 PM
1tonpig's Avatar
1tonpig
I see this is an older post are you still having this issue?
