Help! Quick plz clutch issues
Old Sep 5, 2011 | 10:09 AM
  #21
bg1995redneon's Avatar
bg1995redneon
Originally Posted by smokey_1
ok i checked the codes manually and i came back with code 12 but thts bc i took the battery out to change the clutch and i also got code 32 witch is egr system failure i went and looked at the engine and found tht the erg sensor was not there at all and nver had been since i bought the car so thts were my misterious extra plug goes and the 3 extra vacum lines but my Question is if the sensor was never there b4 how come my cel light never came on b4 i changed the clutch and y is it on now and wont go off
Well, I cannot say why your CEL never came on until after you changed out the clutch because that does not make any sense at all. The missing EGR should have lit up the CEL immediately. I can say that by putting the EGR on it should correct the problem.
