98 Neon Engine Noise
My car needed an oil change badly, it got the oil change, but it's been doing this. And this "engine noise" has me thinking worse for worse, time for a new car. Anybody know what causing it to knock like this, i've had it for about a month, has around 179,000 Kms on it, is a 2.0L DOHC Engine, and while it always kind of has run a little bit ruff, it's never done this, it used to tick a bit, that went away when the crankshaft position sensor was replaced because the car wouldn't start without it. I just changed the oil to, up to specs and everything provided in the manual i also own for the car.
Here is a youtube video i took of the concern.
http://www.youtube.com/watch?v=Tr-CAlQy3rY
I also about a week ago went to change the spark plugs and i found one of them were covered in oil, i believe this is a bad valve cover gasket and seals, but since then i have not at all found any drop or signs of more oil accumulating in any of them.
Is this even worth being looked at?
thanks.
thanks.
