Turn signals
Old Jul 22, 2005 | 02:31 AM
casper's Avatar
casper
Default Turn signals
I am almost sure that it is my multi function switch, but, I have no turn signals. I noticed today that my turn signals and hazards don't work. If I play with the switch, I can hear the relay click and can get the signals to flash for a second. I am going to try a flasher relay 1st because its cheap and easy to do. Does anyone have any other ideas?
Old Jul 22, 2005 | 04:00 PM
casper's Avatar
casper
Default RE: Turn signals
Anyone?
Old Jul 22, 2005 | 04:25 PM
catman22's Avatar
catman22
blown fuse? "if both turn signals fail to blink, the problem may be due to a blown fuse, a faulty flasher unit, a broken switch or a loose or open connection."
maybe the electrical connector at the multi-function switch has wiggled loose?
you could also check the continuity between the terminal on the multi-function switch with an ohmmeter to see if the switch is defective.
Old Jul 22, 2005 | 04:47 PM
catman22's Avatar
catman22
do you need a diagram of the terminals and the continuity to check between them?
Old Jul 22, 2005 | 05:00 PM
casper's Avatar
casper
ORIGINAL: catman22
if you have them
Old Jul 22, 2005 | 05:01 PM
catman22's Avatar
catman22
well here it is, a realy bad drawing of the multi switch and the continuity to check on the terminals, but hey it might help you or someone else.
Old Jul 22, 2005 | 05:19 PM
catman22's Avatar
catman22
well it is still a bad drawing but it should be a little bit clearer. I added the hazard button and the turn switch wand
Old Jul 22, 2005 | 05:33 PM
catman22's Avatar
catman22
Sorry All but I promise this is the last one. Forgot the continuity for high and low beams. and if any portion of the switch is is faulty then you have to replace the whole switch assembly.
Old Jul 22, 2005 | 06:25 PM
casper's Avatar
casper
Thank you for the diagram, I am gonna ring it out tommarow, if the flasher relay does not fix it.
Old Jul 22, 2005 | 10:49 PM
catman22's Avatar
catman22
ide try taking out all the fuses under the hood and putting them back in before i would take the multi-switch out, i had a problem with my 92 tarus wagon not starting right but i took all the fuses out from under the hood, put them back in and it starts perfectly now, maybe just a little bit of a bad connection in a fuse under the hood?
