Both rear turn signals/brake/flashers won't light
Old Oct 6, 2011 | 02:31 PM
barneycar's Avatar
barneycar
Default Both rear turn signals/brake/flashers won't light
Fronts signals/headlights work fine, as do the tail lights(seperate bulb), reverse lights, and the third brake light. Gauge cluster flashes fast when blinkers are on, as to indicate a problem with blinkers. Replaced bulbs and that's not it. Fuses are ok. Replaced the multi-function switch in the steering column. Didn't change anything.
*NEW* Just replaced the flasher relay on the dash fuse block by the door. Did not change anything either. This is starting to become a headache.
For what it's worth in relation to this post, the radio, the guage cluster(half of the time), and the drivers door switch(to dome light) have not worked for at least a year. This car is electrically possessed. This may or may not be relevant. Any idea where I can look to fix the current issue at hand?
