1998 Neon SOHC Rough Idle Stalls
HELP! My 98 Neon SOHC started Idling rough. Showed Code 32. Changed EGR and repaired pinched EGR Vac hose. Worked fine for a few days and started Idling rough again and stalling at idle sometimes, now shows code 52. O2 sensor and wiring look fine. Gets good spark and good fuel pressure. Gonna try cleaning the throttle body and IAC. Any other sugestions will be greatly appriciated.
I had a bad plug wire once ,it made my car run rough[:-],also leaky vacuume lines can do it.
ORIGINAL: j_lrobson
