1996 Neon
Old Jul 27, 2005 | 11:17 PM
mikerike's Avatar
mikerike
Default 1996 Neon
Hey Folks,
Newbie
I am looking at a 1996 Neon, Auto 2.0 liter for $400.
Front nose damage,
Will need new hood,radiator and front crossmember
Is it worth the effortAm buying to fix for grandson.
And if I get a positive response, what a some mods I should put on reasonably.
Old Jul 28, 2005 | 06:16 PM
casper's Avatar
casper
Default RE: 1996 Neon
Sounds like a good buy to me. How fast do you want to make it??
Old Jul 28, 2005 | 10:02 PM
jimmasterK's Avatar
jimmasterK
I've heard the first 3 mods you should do to a 1st gen Neon are:
CAI
Exhaust
UDP
And I'd buy that, shouldn't be too big a deal to fix up. You're getting a really decent price on that.
Old Aug 21, 2005 | 08:48 AM
Brians95NeonSport's Avatar
Brians95NeonSport
-CAI (iceman, around $200 new, relocates battery and is true cold air intake easy install)
-if it is DOHC don't worry about Exaust.
-Mopar PCM(around $200 new remaps Air/fuel, eliminates speed limiter, bumps RPM cutoff to 7500, easy install)
-prothane motor mount inserts ($40- $50 for all 3 mounts, eliminates wheel hop, broken front mounts on MTX)
-underdrive pulleys
-bored Throttle Body, 55mm is plenty without doing major mods to intake and heads. under $75
probably most noticable upgrades to start with, other than good Turbo setup, then you are looking at $$$$
Brian
