help 95 neon
Old Aug 8, 2005 | 01:10 AM
mattnjami's Avatar
mattnjami
Default help 95 neon
hi ppl i giot this 95 neon and when its cold it will run fine you can run the rpms up and all after it warms up or you turn it off and start it back up it will idle but try to rev it up and it backfires and spits and sputters this thing has me frustrated ive never ran across a car that i cant figure out but this one has me so damn frustrated and cant figure it out ne clues will be greatly appreciated ive tried the camshaft position sensor the crank sensor map sensor getting no codes on the cel just will idle start right up but cant get it to rev up spits sputters and tries or does die backfire
Old Aug 8, 2005 | 02:28 AM
ViperGTS's Avatar
ViperGTS
Default RE: help 95 neon
Make sure you post this also in the 1st generation Neon forum. People there can help you faster Matt. Btw, welcome to the site!
https://dodgeforum.com/forumid_121/tt.htm
-Matt-
Old Aug 8, 2005 | 07:27 PM
Daksport1pa's Avatar
Daksport1pa
Welcome to the site.
Old Aug 18, 2005 | 12:36 PM
sixtythreechevy's Avatar
sixtythreechevy
Throttle position sensor?
Old Aug 18, 2005 | 01:28 PM
casper's Avatar
casper
1st thing to do is check for codes.How to read codes
