98 neon sport dome light dont work
Old Feb 15, 2012 | 03:50 PM
BTMFDRNeon's Avatar
BTMFDRNeon
Default 98 neon sport dome light dont work
my dome light will not come on with the headlight switch or while the door open. i lubricated the switches on the door frame and all i hear is clicking. what causes this and how can i fix it
Old Feb 15, 2012 | 06:20 PM
95neon1025's Avatar
95neon1025
dont mean anything mean by this but, did u replace the bulb? check fuses and make sure that the wires in the dome light is actually attatched.
Old Feb 15, 2012 | 07:52 PM
BTMFDRNeon's Avatar
BTMFDRNeon
Ya changed the bulb and all the wires are attached. fuses checked fine and replaced them. only thing i noticed was the door switches on inside were kinda melted
Old Mar 29, 2012 | 10:00 AM
Mok4200's Avatar
Mok4200
To be honest i had a similar problem, im going to guess you have an aftermarket stereo, im not sure how but when i was installing my new stereo a yellow wire popped out and apparently that was the power wire to my dome light, try to check your wires and see if the same thing happened to you
Old Sep 25, 2012 | 09:18 AM
JKat's Avatar
JKat
wouldnt the power to the dome light be a small pink wire?
