1995 Dodge Neon Sport Issues
Old Aug 10, 2005 | 12:37 AM
alonewithyou's Avatar
alonewithyou
Default 1995 Dodge Neon Sport Issues
I have a 1995 Dodge Neon Sport 4dr. that is having some troubles.
Recently, the turn signals have started to go a little weird on me. The left turn signal specifically. When I turn on the left turn signal, it turns on my front left turn signal and my rear hazard flashers. If I step on the brake, the left turn signal freezes and is just a constant light. If I flash the brites on and off, it will take care of the brake problem, and then if I pull back slightly on the turn signal lever it fixes the problems with the hazards.
Not really sure what could be causing this. Just recently had it taken in to get checked out and both front (I think) signal bulbs were replaced.
The cruise control does not work any longer and the spedometer sometimes goes dead, but is revived by softly hitting the dash or repeatedly pressing the trip odometer reset.
Just wondering if anyone has any guidance to offer on the issues.
Thanks.
Old Aug 10, 2005 | 10:44 AM
catman22's Avatar
catman22
Default RE: 1995 Dodge Neon Sport Issues
as far as your gauges look for this post(Sticky)
Top: [FAQ] 1st gen gauge cluster repair
it is above the threads in the fist gen page.
everything else is most likely a ground issue.
