Wiring up amp and sub
Old May 14, 2005 | 02:10 AM
harrowneon's Avatar
harrowneon
Default Wiring up amp and sub
Im just plannin on wiring up an amp...
first question - someone said theres a fuse i have to put on the battery cord or sumthin to the amp??.. for it to work..is that true??..
or can i just run the remote /rca/battery back to the amp and ill b fine ....??
second question- i put a kill switch in the panel with the rear defrost in it..perfect spot..but for the kill switch.. Wat wire could i run for the kill switch to the amp?..so i can kill the power when i need to??..
thanx for al lthe help need ne indept explanation just ask..thanx
Shawnzy
Old May 14, 2005 | 03:49 PM
highrevr/tflea's Avatar
highrevr/tflea
Default RE: Wiring up amp and sub
No you dont need a wire fuse for it to work it just protects it from surges and such .... id just get a deck that you could do sub control.
Old May 14, 2005 | 09:05 PM
harrowneon's Avatar
harrowneon
subcontrol??..
i think i got that on my deck..mines a Sony Xplod and i think there is a setting but its way more of hassle then jus hitting a switch
Old May 14, 2005 | 11:27 PM
catman22's Avatar
catman22
Just go to walmart and buy the scosche amp install kit, it'll have the rca cables and your power wire(with fuse in it), remote amp power on wire(power antenna from the back of the deck), and speaker wire, possibly some other stuff in the kit too and instructions to boot oh and before the question gets asked it is possible to hook up more than 1 remote amp power on wires to the power antenna wire from the deck,
i only know cuz i have a 200W pioneer amp fro my 6X9's and another 200W pioneer amp for my 6 1/2 rounds in my doors. now i just wish i hadnt broke that drivers windos 2 years ago cuz when my 6 1/2's pound they are allways shaking the little glass pieces that i couldnt get out with the shop vac
Old May 15, 2005 | 08:47 PM
tchase's Avatar
tchase
While you certianly don't need a fuse for the amp to work, running unfused wires directly off your battery isn't exactly a good plan. If you don't already got the wiring just grab a kit like the one already mentioned. Also if you didn't already know, it's better to put the kill switch in the turn on lead than the power wire.
Old Aug 8, 2005 | 02:26 AM
pimped_neon_RT's Avatar
pimped_neon_RT
man you guys buy cheap ****!
Old Aug 8, 2005 | 03:33 AM
pimpberetta's Avatar
pimpberetta
Some people dont like to have their mirrors fall off or truck latches busted open like us
Old Aug 10, 2005 | 04:02 PM
catman22's Avatar
catman22
what do you mean "man you guys buy cheap ****!"
Pioneer amps and speakers arent too bad for a daily driven family car, and Scosche is either made by pioneer or pioneer is made by Scosche, I know that because on the bottom of my amp box it has Scosche written on it.
