96 neon stalling
Old Oct 31, 2006 | 02:38 AM
slow_hemi's Avatar
slow_hemi
Default RE: 96 neon stalling
may also wanna look at the IAC on the throttle body. have had that problem 3 times and it fixed it instantly every time....even though this problem was on my '05 mtx.
Old Oct 31, 2006 | 02:42 AM
winsettz's Avatar
winsettz
Check resistance of the IAC, or remove it from throttle body?
In any case, I'm thinking of removing and cleaning off my TB, I get a nagging suspicion it's dirty beyond all redemption.
Old Oct 31, 2006 | 02:59 AM
slow_hemi's Avatar
slow_hemi
not sure what the resistance of it is but mine was a warranty swap out each time
Old Oct 31, 2006 | 03:05 AM
winsettz's Avatar
winsettz
My car's an ancient SOB, no warranty for me!
I'm probably gonna have to figure out how to remove it from the car...Haynes and FSM don't appear to have it.
Old Oct 31, 2006 | 12:46 PM
das2123's Avatar
das2123
ORIGINAL: SirAlleyCat
It seems strange that you have such a serious problem and no service engine light. Can you have someone scan the vehicle and post the results? It might give me somewhere to start since there are a multitude of conditions that could cause that problem.
I am looking for the Max and Min on the following after the engine has warmed up and you have driven it around the block.
Intake Manifold Pressure
Engine Coolant Temp
Engine RPM
Intake Air Temperature
Long Term Fuel Trim
O2 Sensor B1-S1
O2 Sensor B1-S2
Also check for misfire counts if your scanner will read it.
Did you not realize that the original post was over a year old. Fuel pump/filter problems won't throw a code anyways.
Old Nov 6, 2006 | 05:04 AM
Youngstown97Sohc's Avatar
Youngstown97Sohc
From: Youngstown , ohio (muder capital per capita u.s. )
well i would have to bump this with an IAC reccomendation , bc my car was just in (as das knows) , and my fuel pressure at the rail and at the tank are within 2psi , and my plugs , wires , air filter , egr , and coolant are all go for launch , and i sitll have the stalling problem... completely intermittent , just kinda puts out and shows me an oil light.. either that or its telling me to rub the dash and pray a genie pops out...but im pretty sure its the oil light..sometimes i get a battery light too... i have noticed that when it does this at night , the lights dim , so im going to have my alternator checked , my battery checked , and im going to throw some codes tomorrow (today)...
gl and lemme know if you got it fixed...
hova
Old Nov 9, 2006 | 10:10 PM
Youngstown97Sohc
well i tried throwing codes and it just sat there and did nothing... so i tried again.. on off on off on off on off on ....nothing.... trya again....nothing... then i noticed the nieghbors looking out the window at me like im crazy...so i got out , rubbed the side of her , got back in , and did it again... still nothing , i was tempted to hump my neon , but they are just begging to put me into the loony bin...
hova
Old Nov 9, 2006 | 11:31 PM
das2123's Avatar
das2123
It's only...on, off, on, off, on.
Old Nov 10, 2006 | 12:17 AM
Youngstown97Sohc
maybe thats why it didnt throw any codes.... guess its a really good thing i didnt hump it yet... now i can go out tomorro , pull codes , and then hump the car...
lol
hova
Old Nov 21, 2006 | 08:45 PM
SirAlleyCat's Avatar
SirAlleyCat
Eeep! My bad dog. [:@]
