1995 possible wheel upgrade - hub info
Old Apr 10, 2012 | 05:58 PM
bg1995redneon's Avatar
bg1995redneon
Default 1995 possible wheel upgrade - hub info
I have a 1995 Dodge Neon with the original 4x100 wheels. Front disc, Rear drum. I need to replace the hub bearings, and quite frankly, it costs LESS to replace the hub and bearing on a 5x100 neon then a 4x100 neon. I understand why as neons only used 4 lugs for 95 and part of 96 - supply and demand.
I could just replace the bearings, but by the time I buy the bearing and have someone press the old bearings out and press the new ones in, I will have just as much into it as just changing the whole thing. I don't have the equipment to do it myself.
13" tires are starting to get relatively rare and awfully EXPENSIVE at local shops (limited available stock), so I have had to buy online just to keep the price reasonable.
If I switch to the 5 lug hubs, I can go with the OEM 14" tires (15"?) and I can get those rims easy! They are a LOT of them out there. A lot more then the 4x100 13's and cheaper too.
So here are my questions to those of you who have done this already:
1) Can I buy the following (as an example):
Moog Front Hub kit 5 lug (Advance Part No. 518512)
Moog Rear Hub kit 5 lug (Advance Part No. 512023)
instead of:
Moog Front Hub kit 4 lug (Advance Part No. 518511)
Moog Rear Hub kit 4 lug (Advance Part No. 512021)
and just put them on?
2) Do I have to modify anything else - brakes (front/rear), linkages, lug nuts, etc?
3) If I go with OEM 14" tires on 14" OEM rims (15?), will my speedo be off? I don't think so as it is a function of the VSS on the tranny, but just want to be sure.
4) Any changes required to steering controls? tie-rod ends, bushings, ball joints, etc?
5) Any diff between 1st gen and 2nd gen neon 5 lug rims? Any problems using 15" rims/tires for a 1995 model instead of 14"'s?
6) Any gotchas I need to be concerned with - backspacing, etc.?
I can afford to do this if all I have to buy are rims and hubs. Anything else and it just isn't worth it. I can get both of the above at my local JY.
Old Apr 12, 2012 | 03:14 PM
das2123's Avatar
das2123
instead of:
I honestly don't see why not. I know people swap ACR hubs onto to base neons and so on. I don't see why it would be different for a 4-lug to 5-lug.
I don't know the thread pitch and size of a 4 lug hubs, but just double check the part numbers to see if there is a difference.
It may be slightly off +/- 1-2mph but nothing too bad.
Don't see there being any.
1st gens are 14" and 2nd gens are 15" but both are 5x100 bolt pattern.
I don't know if the brake setups are the same from a 4 lug to a 5 lug. So I would double check all parts, brakes rotors and so on to verify part numbers. Might as well do a rear disc conversion while you are at it
