My cluster lights along with the lights for the shifter and a/c control panel WON'T WORK! My speedo, temp. gauge, fuel gauge and turn dignals work along with my dome light. I changed the lights in the cluster, shifter and a/c panel and still nothin. I checked fuses... all good. I'm confused as to why they won't work but other things are. Help would be very very much appreciated.
Also since I forgot to mention before, it's a 1995 neon coupe. I just pulled off the dash and found a solid black wire with a yellow stripe blistered very badly. I noticed there were two but only one was blistered. Also, my taillights, headlights and side markers work when I turn on the lights. If the blistered is the culprit, can I end up changing out the entire wiring harness under the dash? If so, where could I possibly get one and does it have to come from the same year (or gen.) and style as my current car.
Can you elaborate on how you did this. The car runs how it is but I don't really driving without being able to see my speed since I do alot of early morning and night driving.
I went in and taped up all the burnt wires and if any was burnt in two I put them back together or replaced the badly burnt parts in them then I cut the wire that was burnt away from the switch and took a test light and turned the switch on found a hot wire and turned the switch off and when I found one that went off with the switch I tied the wire I fixed in with it and never had a problem again drive the car for months b4 I sold it because of the transmission
Nah. I'm not too high on the idea of getting in there and splicing wires. I think I'm just gonna go too a JY and find and entire wire harness and try to throw that in there. After everything I've done to this car these electrical problems just royally **** me off.
Much to my suprise it was only the dimmer switch! I went to the JY today and spent two and a half hours trying to get out the interior wiring harness. I got probably 75% done but the heat and humidity became too much. So I grabbed a dimmer switch and a cluster (now I have a TACH. HELL YEAH!!!) Put them in when I got home, first the dimmer, and freakin' presto, the damn cluster lights work.
