error code 31
Old Sep 15, 2012 | 11:43 AM
chwrench's Avatar
chwrench
Default error code 31
engine service light is on error code 31 is on says it is evap purge camister solonoid has a prob. what do i do to troubleshoot this problem
Old Sep 15, 2012 | 02:14 PM
I_Ride_Neon's Avatar
I_Ride_Neon
Its above the passenger motor mount has a plug and 2 vacuum lines ran to it. I would check the vacuum line, the lines to and from canister, and back by the tank. A leak in the system can cause the light.
