Fan relay help
i have a first gen and my CEL came on and i got it obd tested came up as my radiator fan relay. so i bought a new one and installed it. ( under the battery tray) but still nothing happens tired of overheating in trafic!!!!! help please
Check the fuse. Then jump the fan and see if it turns on manually. After that you need to make sure the computer is commanding it to come on.
Fuse 10 (15amp) Hot in run only. Found in the fuse box inside the car I think.
Also check Fuse 5 (30amp) in the PDC under the hood.
Light green and Black should be the 2 wires on the fan pigtail. The black is ground.
That would work but most people don't like to rig stuff and would rather just fix it so it works how its suppose to. It would take under an hour to figure out, was it worth hitting a switch for 3 years? :P
Lol so far yes I went through a lot of trouble to end up with a switch at first it sucked but its almost normal now lol I bought new fans relays fuses tested wires did everything but always had that problem even new pigtails too
so i figured it out there was a bare wire that was the ground fixed that now i have the cod 4515 or 1545 wasnt sure but its the cooling system and i have no idea what to do tryng to sell the car and i need that code off i tryed to turn it off with the scanner and it didnt work any ideas.
Check your ground wires. Last summer I had a grounding issue. I would be driving and the temp gage would randomly spike but the fans were not kicking on... the warning tone on my dash would go off. Seconds later the fans would kick on.
Used the old trick of kicking heater fan to draw heat from engine when at lights. Thats fun when it's 90.
All I had to do to fix it was replace the short neg wire going from the battery terminal to the fram by the driver side head lamp. For good measure I ran another line to the fender. Just used solid 12 gage wire laft over from rewiring a house.
Only noticed it was a bad ground right off the bat cus I burned my hand on the screw while checking the engine.
Code cod 4515 or 1545?
